Intermittent stage lights effect on MacBook Pro 2019
Hi everyone
I've been the happy owner of a 13" MacBook Pro TouchBar 2019 since July 2019. Everything was working great, until a few weeks ago, my screen started randomly showing the infamous "stage lights effect". (see picture here)
Note that the computer was never tampered with, never saw any liquid, I've been taking great care of it over the years.
However, the problem seems to be software to some extent because running pmset displaysleepnow
, then re-unlocking it gives me a bright screen for a few minutes... Then it goes back to stage lights.
I haven't been able to determine what makes the problem appear, but it usually never takes more than 10 minutes to appear once I start using the computer.
Is that a known issue? I know the Apple doesn't do repair programmes for MacBook Pro 2019 for the flexgate issue. And as far as I know, the programme for the keyboard, which may have helped, has been discontinued too.
Thank you in advance for any suggestions!
7 Comments
I have 2019 16inch MacBook Pro that I purchased in Feb 2021 - and I just started having this same issue: stage light effect. It's not all the time, but usually once it starts it won't stop. If I place my Mac in sleep and then wake it up again sometimes that temporarily fixes the issue. Not sure if I should try to trade it in while I can get 605 for it still... or if apple will fix this? Anyone have any luck?
by Sebastian
For the record, I did bring it at the Apple Store where they suggested I trade it in (for a meagre €400), because "paying €1200 to repair a 2019 MacBook Pro isn't worth it" – but that was of course assuming I was to buy a new €2000 MacBook Pro.
This is so bad, and on so many levels...
by T K
@walski I'm having the same intermittent problem... It often occurs when using the dedicated GPU (Camera Raw, for example). Did you find a solution? By the way, two months ago they supposedly fixed the flexgate issue of my MacBook Pro late 2016 15", but now I'm experiencing these stage effects that get fixed after running 'pmset displaysleepnow', but sometimes I need to close Adobe Bridge, from where I trigger Camera Raw.
by fontcl
@fontcl - The fix was a patched cable or a new display assembly?
by Dan
Hi @danj
It was a patched cable and they kindly test it saying that everything was ok and found the problem to be quite strange. They even offered to patch it again and replace the panel board display. However, they admitted that they weren't entirely sure where the issue was originating and couldn't guarantee that it wouldn't happen again.
by fontcl
Show 2 more comments
