27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160 Questions View all
Is possible to upgrade build in fan to a Noctua one?
My second hand Thunderbolt Display easily getting hot, I can't sure is the fan works or not.(But when the environment is quite, I can heard "bo bo bo" sounds.) Can I replace the fan which has higher RPM with same voltage?
Add a comment
1 Answer
Chosen Solution
Sorry Apple uses a custom fan unit. It’s likely the fan is either damaged (out of balance) or loaded up with junk.
Given the age I would start off just cleaning out the dust and debris that’s collected inside. I’ve found stapes and small scraps o paper mess up the fans in system
I find a small soft paint brush and a can of can’d air will do the job!
Here’s one source for the needed fan 27" Thunderbolt Display Fan - Apple P/N 922-9936
Score 3
Add a comment
Add your answer
imjeremysome will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 61
