Released in August 2014, the Lenovo Y50-70 Touch is part of the Lenovo's Y series of laptops. Equipped with a dedicated graphics card and a 15.6" touch screen, the Y50-70 Touch is specialized for gaming.
36 Questions View all
Which screens are compatible
I've recently bought the Y50-70 Touch for pennies but it requires replacing the screen. I've done some research and I've already disassembled the broken screen, right now I'm stuck with picking out the compatible screen mostly because I'm a bit confused about a few things.
Could someone explain to me why there are 2 different types/models of this laptop where one has a 30 pin connector and the other has a 40 pin connector? (I've got the 40 pin one.)
Also I was confused about the resolution as I see that there are UHD screens and FHD ones, I was thinking with going for the UHD but I'm not sure where I could make sure if my model is compatible with that resolution.
About the touch/non-touch functionality... So I know there's 2 options either getting a touch screen or a non-touch screen but would also need a non-touch Bezel and a non-touch LCD cable which I don't really care about the touch functions but the prices seem similar between the 2 screens when you add the required cable and bezel for non touch screen so I'm fine going with whatever.
Add a comment
1 Answer
Most Helpful Answer
Hi @swidro
Usually a 30 pin connector is used for non touch models and a 40 pin for touch models
Here's a link to the parts for your model which will help.
Here's an image showing the part numbers for a Lenovo Y50-70 Touch, Type 80DT which shows the part numbers for all the LCD panels that are compatible with that model type.
The model type info is found on the product info label on the bottom of the laptop
(click on image)
Search online using the part number only to find suppliers that suit you best.
Click on Select Commodity to find any other parts that you may need for the laptop
Note: the other two types shown in the image i.e. 20349 & 20413 don't have any info in their parts list so presumably they use the same parts as the 80DT model.
Score 2
Add a comment
Add your answer
Eryk Swider will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 34
All Time: 192
