The iFixit Precision Bit Driver is an aluminum or plastic handle that fits 4 mm bits.
12 Questions View all
The small screw stuck in the top of my iFixit Precision bit Driver
Dear Supporting Team,
Kindly I have the trouble as follows:
Somehow a small screw stuck in the precision bit Driver at the magnetic part.
I try to pull out by using wax and other magnetic device but it is still not solved.
Kindly I need your help to know how I can withdraw the screw from the driver.
Thanks,
Mohamed El-Sayed
Score 1
Add a comment
Most Helpful Answer
I've had something happen like this. I was able to use a set of Precision Tweezers to pull it out.
Precision Tweezers Set Image
Product
$9.95
Score 2
2 Comments:
Hi Jacob,
I tried, but the problem is screw wedged in the driver
Thanks for your reply
by
@mh7 - See if a dental pick can get behind it, if not you’ll need to get a new handle.
by
Add a comment
Flick it, hold the driver with the bit part up and flick it down really fast. Centrifugal force should make the screw come away from the magnet.
Score 1
2 Comments:
Use a pillow case to catch the screw!
by
Hi Dan,
The problem is screw wedged in the driver
by
Add a comment
Add your answer
Mohamed will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 42
All Time: 636
