Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
163 Questions View all
Can I fix a burned Pcb Board caused By OverVoltage?
I got an Xbox one controller model :1708 and The pcb of the buttom Board is burned around The U1 and the D23 and C7 C6 R17 R20 it is Completly Burned Can I rebuild It Using The Cu thine Cabels using the Diagram and most importan Can I fix or no And thanks Befor .
Note : The prewies owner tell me that he put it into a bad quality phone charger so it might and over voltage via USB caused all that .
Score 1
Add a comment
1 Answer
Most Helpful Answer
AbdelKarim Lakehal that is some really impressive damage. I will never say it can't be fixed but there will be plenty of obstacles. First your pads and traces are pretty much gone. Second you will need a list of the components and a schematic to see what goes where. You can get some from pictures like this
and some good information from here as well. That will help you find some of the traces but not all of them. Ultimately it's a big job and it might be more economical just replacing the board with one from here Xbox One S Controller (1708) Motherboard
Keep the one you have and work on it at your time. Who knows, you may just succeed. After all, Repair is War on Entropy!
Xbox One S Controller (1708) Motherboard Image
Product
$14.99
Score 1
Add a comment
Add your answer
AbdelKarim Lakehal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 237
