Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
748 Questions View all
Why can't my MacBook boot up
I replaced the battery of my mid 2009 MacBook and the hard drive with a new Solid State Drive. The MacBook, however, would show a folder with a question mark. I haven't replaced the ram but when I did, it wouldn't displace anything. The battery isn't faulty because I have inspected it. This is a serious problem.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi
When you see a question mark that means that the mac doesn’t know what to boot from(it also does this if there ISN’T anything to boot from)
If you haven’t reinstalled macOS you will need to do that to fix your issue
Here’s a guide in doing that
https://support.apple.com/en-gb/guide/ma...
If you already have macOS installed I suggest you reseat the cable going to the SSD:-)
Hopefully this helps
Any questions please ask
Score 1
1 Comment:
Was the system ever patched? If so see my thread "Cannot access boot utilities - greyed out EFI Boot - SOLVED!" hopefully that helps someone!
by
Add a comment
Add your answer
Neon Knight will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 50
