Green power Light keeps blinking
Green power Light keep blinking
Hi,
Press and hold the power button operated for >10 seconds and then release to ensure that the PC has fully shutdown in case it is in a sleep or hibernate state.
Once it has shut down try turning it on and check if it starts OK
If it doesn't start and boot into the OS then try a power refresh and check if that resolves the problem.
If it turns on OK there may be a message stating that the time and date are incorrect. This is normal as the BIOS has been reset. Once the D&T have been corrected the message won't appear the next time that the PC is started.
Thanx I'll try getting another battery
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 160
