Washer will not drain
I took pump and hose assembly off and cleaned out but it still code says won't drain. Would it be stopped up someplace else? And how do you take it apart?
There are several reasons why a washer may not drain properly. Here are some possible causes:
If none of these solutions work, you may want to consider calling a professional appliance repair technician to diagnose and fix the problem.
I unplugged the washer, took off the hot & cold water hoses, flipped it on its back, and took off all drain hoses, and pump, but to my surprise, everything was open and the pump was not that dirty. I cleaned out everything anyway pump was working fine. I was expecting to find clumps of dog hair because my grandson lives with us and has a very large dog that sheds a lot. The two commodes sinks in bathrooms, shower, kitchen all drain fine. But after I put it back together and got it going, it did the same thing with the first load, I managed to finally get it to drain, but than after that it started working fine. It's been a few days now and it still is working good. It's one for the books I will tell you.
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 110
All Time: 3,277
1 Comment
Hi,
What is the make and model number of the washer?
by jayeff
