Why won't my phone work after falling in water
can my phone be fixed after falling in water 2 years ago and it has not been able to turn on?
After 2 years you'd be very lucky. New screen, new battery, possible unrepairable corrosion on the motherboard. Nothing to stop you having a go. Ideally you'll need a microscope, hot air station. Isopropyl alcohol and a toothbrush. Start with removing the board, remove any shields and clean any corrosion, as best you can anyway. Replace the board and try charging it. All depends on what is was damaged with, toilet water, sink water etc. I have a iphone se in a similar state. Just need the energy to strip the board out lol.
Thanks Nigel, I agree that it will be highly unlikely to fix, but I can only try lol.
@Aut you can only try, hopefully you'll succeed. Good luck with it.
try cleaning the board with alchole this should remove some of the corrosion on the board
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 201
