Your DIMM1 and DIMM2 Module Organization is not the same
How do I fix the error "Your DIMM1 and DIMM2 Module Organization is not the same?"
my acer is a E5-510
my acer is a E5-510
Have you recently upgraded the memory in the laptop?
The message is saying that there's a problem with the memory modules in the laptop e.g. they're not the same or perhaps one is faulty.
First try a power refresh and check if that resolves the problem.
If still no good, try reseating (remove/replace) the memory modules and then check.
Here's a video that may help. I realize that it is not your model but it should be the same as far as the location of the memory slots. Not the easiest as they're on the underside of the motherboard.
If it still fails after doing this then most probably there's a faulty memory module or memory slot on the motherboard. Try starting the laptop, using only one module at a time to see if you can isolate which module or perhaps which memory slot is the problem.
Meu Acer E5 estava assim, troquei o diodo duplo da CMOS no meu caso o d22, algumas placas é o d23 ou d5, ele é o responsável por chavear os 3.3v da bateria da bios (data/hora) e da tensão primária, aparentemente medindo parecia não estar com problema mas alguma pequena variação nele pode dar esse tipo de defeito. Troquei e sanou o problema.
Google translate:
My Acer E5 was like this, I changed the double CMOS diode in my case the d22, some boards are the d23 or d5, it is responsible for switching the 3.3v of the bios battery (date/time) and the primary voltage, apparently Measuring it didn't seem to be a problem but a little variation in it can give this type of defect. I replaced it and it fixed the problem.
Past 24 Hours: 6
Past 7 Days: 52
Past 30 Days: 207
All Time: 21,875
1 Comment
what to do 2001 i am buy
by thiru
