Televisions made by LG.
30 Questions View all
Dim grey screen, no picture, good sound.
Hello,
I have an LG 55 inch smart tv, 55UK5090PUA. The screen suddenly went from a solid picture to a dimly lit grey screen. There was no transition where it was intermittent - it just stopped displaying a picture, although when I pressed hot buttons to get to a streaming service, I could hear the sound.
After trying the reset/troubleshooting, I replaced the Main Board with the same replacement part (EBT65513202), plugged everything back in, with the same results. I guess now I have a back-up.
Does anyone have a suggestion on what I should check next (and how)? With the back off the TV, you can see the back lights on for sure, so I believe there is juice moving through the power board.
Thank You in advance,
Evan
Score 1
Add a comment
1 Answer
Chosen Solution
I don’t understand what I did, but I found this YouTube video of a guy that ended up blocking one of the paths on a flex cord that was shorting out between the screen and T-Con … and it worked for my issue too.
Here is the link, in case anyone else has the unanswered problem similar to mine. I’m sure there is a more permanent fix with new parts, but I’ve spent enough time and money on this TV already, so I’m going to call it good.
https://youtu.be/tCknTVbZ3I8
Add a comment
Add your answer
Evan Winney will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 50
Past 30 Days: 228
All Time: 3,075
