Why is wifi not working
When i switch on wifi, it does not show available routers & it does not access any wifi connection
Hi,
Try using the phone's WiFi as close as possible to your network router i.e. <10cm and check if it detects the networks and connects to it.
If it does then it may be a loose antenna problem.
Here's an image of the phone taken from a teardown video that shows the antenna connections at both ends of the phone.
(click on image)
If it still doesn't work it may be a problem on the systemboard. Here's an image of the no BT/WiFi troubleshooting flowchart that may help.
(click on image)
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 16
All Time: 334
2 Comments
WiFi not work
=== Update (05/11/24) ===
Samsung A10 WiFi not work
by Nauman rajput bhtti
