Screen glitching after glass/digitizer replacement **URGENT**
Backstory, I'm no professional but have been fixing iPhone/iPod Screens since I was 8 years old. I've always been the go-to to fix iPhone screens but have only ever been self taught from iFixIt Guides.
Anyways - I have tried to repair only my 2nd iPad ever from a family member the other day with just the worst luck. Everything has gone wrong with this repair and I'm so stressed at this point, I can't afford to dump any money into this as I believe I messed this up on my own.
Firstly, I was only asked to replace the screen as it was cracked. Ok, easy enough. Worked on it the other day and finally after 4 hours, got it all back together and done. Went to put the screen on and didn't realize the frame was gashed and CRACKED THE NEW SCREEN.
Anywhom, I said whatever and bought a new one and went to go replace it.
ISSUE THAT I NEED HELP WITH BELOW
- Did a function test with the old cracked screen and the newly cracked screen. All was working as should.
- After installing the new screen(2nd new one) it is now found that the LCD screen is glitching.
- It is that "Ghost Touch" and moves the screen around, types in random passwords ETC.
- I thought maybe it was the LCD itself. Replaced that, did not fix issue.
- I tried with old glass digitizer, this ghost touch glitching problem is still there. I know it's not the digitizer.
- Even if my hands are off the LCD screen and it is ONLY the LCD screen plugged in, I'm getting this ghost touch issue.
- Checked the board connectors and all pins seemed fine. From a visual inspection of the Micro PCB connections, all looked to have no issue. Do not have a microscope, as I'm NOT A PROFESSIONAL. This was only confirmed from a visual inspection.
I really appreciate the help and support, as I've been stressed and really losing it over this thing. Not really sure where else to go.
