The M2 is Apple's second iteration of their System on a Chip for Mac, featuring integrated GPU, CPU, RAM, and other components for improved performance and efficiency. The base M2 in the Mac mini has an 8-core CPU with four high-efficiency cores, four high-performance cores, and an integrated GPU with 10 cores. Identified by model number A2686.
How to reformat SSD
how to reformat external ssd
Score 1
Add a comment
Most Helpful Answer
Open launchpad, click the "Other" folder and select "Disk Utility" (in the red box in the attached image),
and choose your external drive from the sidebar. Then, from the top bar, select erase. It will pull up a window with numerous options. If you just plan to use it for storage, just leave everything at the defaults and click erase. A pop up will appear asking you if you are sure. Tell its to go ahead and erase. It'll load for a minute or two and then, Presto! Your disk is erased!
Score 1
Add a comment
disconnect and other storage devices, and try factory reset.
Add a comment
Add your answer
Rolando “Dr J” Villaraza will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 1,280
