any new firmware or software?where can I go to download and install
where can i go to download and install the newest firmware software the easiest. i believe my is coruppted
there is no new updates as it is no longer supported sorry,
heres how to restore:
hold down power button
if you see the andriod robot with a red exclamation mark, you have a issues with andriod and if you don't its fine.
use the volume buttons to scroll to data wipe/reset
and then your done!
It's google locked I'm try by hand thru accessibility but it doesn't have a the second part where you can use speech as a way to accept access Google Assistant can then open up settings so I need to probably nothing else Read download the original firmware the stock it's just hard to find the actual places to download anymore because all people do is talk and type on their at every time you search it winds up being a dead end and there's no download but I need to find a way to unlock the FRP as easy as possible
you don't need to access any of that to restore android if your data is corrupted, but if your trying to remove i google lock, you need a new logic board as goole locks are tied to that and therefore the phone will do to keep that tied to it, even ruining itself and making itself unstable and unuseable.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 63
