Is there anyway to bypass the original bitlocker key
is there anyway to bypass the bitlocker key on my laptop in order to factory reset
Update (03/15/23)
i tried the Shift & Enter buttons at the same time and took me to where it asks to provide the bitlocker key
Add a comment
Unfortunately, there has been no ways that I have found to bypass the bitlocker key. In instances like this I would recommend replacing the harddrive. Since bitlocker is protecting the data that I on the drive. Side note: I would also recommend checking for the bitlocker key which would be in the Microsoft account associated with the laptop. The one you use to log in with.
Add a comment
Take the drive out, connect it to a working PC using a USB adapter, use diskpart clean function to totally clean the drive.
You will lose all data, if you don't care about it it's fine.
Add a comment
Add your answer
Jason Gardenas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 273
