Why is my power adapter get over heated and problem facing while insta
Sir my adapter get overheated as well as while i was resetting my device and due to something my laptop get off and after that time i m facimg issue like windows cant in this device to install wi.dows restart the installation , sir i will be very thankful if u will provide me a solition
Add a comment
1 Answer
How old is the laptop and power supply and is the power supply (adapter) genuine? It's normal for an adapter to shut down if it gets too hot, likely from an internal repairable issue. See if you can swap it with another unit while installing. Many electronics shops will let you try theirs at no charge before you buy to ensure it really is the problem. Failing that, I'd be looking at the battery next.
Add a comment
Add your answer
Aaditya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 52
