Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
216 Questions View all
Charger broke in charging port.
Kid broke off charger in the charging port. Its 2 small pieces stuck on the each edge and won't let you put a charger in. Not sure if its fixable, I tried poking it out with a knife and with the Pureport tool and nothing.
2 Comments:
@joserincon40200 What gereration is your iPad (e.g. iPad 2)?
by
ipad air 2 wifi edition
by
Add a comment
If you aren't able to retrieve it with tweezers I'd recommend calling a repair shop to see if they have any tools to remove it. Some places will do that for free over the counter if it's easy enough for them to do. In the worse case scenario, the port may need to be replaced.
Add a comment
Looks like my charger port is burnt. How easy is it to change the charging port of iPad Air 2? Where do I find the replacement part? I couldnt find the replacement part or method to replace the charging port on iFixit portal.
Add a comment
Add your answer
Jose Rincon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 94
