Power and charging problems
My beats when plugged in shows 4 led lights and won’t charge. It also don’t power on when I try to switch it on but still works with the wire
Hello George,
it sounds like you are experiencing a problem with a worn connection port (that one you put the charging cable into). Delicate connections wear out over time and lose contact. The solution is to replace the port. You can do it yourself if you have skilled hands and a soldering iron (any delicate). Otherwise, find an electronic repairman or other "handyman"
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 20
