Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
545 Questions View all
2011 MacBook Pro 17” works, but no internal display
I have a 2011 macbook pro 17” that boots, works, charges. External display works fine too, but no internal display. No water damage. Reseated lvds cable. Did pram, smc reset multiple times. Nothing worked. How do I debug? Thanks
Add a comment
1 Answer
Most Helpful Answer
Let’s give this a try, take a flashlight aim it into the Apple logo in the lid, do you see a faint view of your desktop and its icon?
If you do you need to focus on the displays backlight logic, if you don’t the displays T-CON logic is likely damaged and/or the LVDS cable is damaged.
Score 1
3 Comments:
Thanks Dan. I was not very clear. It’s not a backlight issue. I tried shining a light to the LCD, and there were no images. Also I tried using a different LCD, and same results, nothing on the LCD. External display still worked all ok.
by
@my980313e - then the logic board LVDS connector is bad.
by
Thanks Dan, I will give micro soldering a shot
by
Add a comment
Add your answer
my980313e will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 71
