Repair and Disassembly guide for the 2020 ASUS G15 G512LI, A laptop produced by Asus for budget/light gaming.
29 Questions View all
Laptop not turning on
Strix g15 ryzen 7 4800h and GTX 1650 ti
The laptop is not turning on , the power indicator does not light up even if charging . The laptop flashes the power light for a brief second at the moment the power is connected and goes dim again ...
Sometime i just let it sit for 4-6 hrs and it generally starts to work again , the laptop is currently not turning on
I have tried unpluging the laptop and holding the power button for a minute or two , and when i connect the charger and try to start it the power light just flashes and the laptop does not turn on .. please help
I have also tried the hard reset when the battery is removed ...
I have look at the forum for any possibile solution .. i have also replaced the motherboard but the same problem persists ...
Any suggestion pls
Score 3
2 Comments
did you check your work on the motherboard? you may have left connectors off of the board or ripped them
by
I have also the same problem, if your problem get fixed plz can you help me
by
Add a comment
1 Answer
Most Helpful Answer
Try a different charger o r charger cable
Score 1
Add a comment
Add your answer
Rashid will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 30
All Time: 619
