Repair and disassembly information for Logitech's MX Master wireless mouse. Released in 2015 and identified by model numbers M-R0052, 910-004956, 910-004955, or 910-005228.
Left click doesn't work all the time
The left click doesn't work properly,
Score 2
2 Comments
My left mouse button double clicks all of the time on 2 of these mice. Will this procedure fix that issue?
by
It may.
if you follow what I have written you will not damage your mouse. It's low risk with a large chance of working out for you. Frankly I am surprised why such a technique is not more popular.
by
Add a comment
Chosen Solution
these clicky, micro buttons can often do well after applying a drop of lubricant. You can remove the top case of the mouse, exposing the guts. Disassembly often requires removing screws which are hidden beneath the low friction Teflon stickers. Remove these with the edge of a blade. Try hard to pull them off without bending or curling them. Try hard to not touch the glue surface.
Sometimes the glue is ruined and you will need to re-glue them seeing that they fall off sometimes. Which is annoying. Don't be tempted to use superglue. Choose something flexible which sets rubbery, so we might be able to pull them off again one day.
You will see clearly the micro button mechanisms for left/right, perhaps others. Take some WD40 and apply a single drop onto each micro switch.
Leave the mouse be for a about an hour. Occasionally press the buttons a few times. We're giving time for the oil to seep inside and coat the teeny tiny mechanism. It will get inside, it just takes some time. Do not apply more oil.
Reassemble the mouse and use it normally. It may take a day to achieve the full effect of the oil. It may work almost immediately. If it doesn't seem to have made any difference at all, do not repeat the procedure.
No mater the outcome, this will not damage or harm your mouse in anyway.
Score 7
Add a comment
Check out device then rechargeable that's.
Add a comment
Blowing air under the button seems to help too. I think it's dust accumulation, since it sometimes works and sometimes not (or only when you push it hard).
Source and more details:
https://www.reddit.com/r/logitech/commen...
Add a comment
I've tried both methods, using lubricant on the micro buttons inside the mouse and blowing air inside, but neither worked.
I also noticed that if I use the mouse without the cover, the left click and double-click work fine, so the problem isn't with the buttons inside but with the buttons on the cover.
Add a comment
Add your answer
A Gpt (Miranteldit) will be eternally grateful.
Past 24 Hours: 81
Past 7 Days: 540
Past 30 Days: 1,843
All Time: 26,578
