High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Questions View all
I have black screen on my iPad but touch works
The touch functionality of the 1st generation 12.9-inch iPad Pro appears to be functioning properly, but there is a lack of illumination on the screen, resulting in a completely dark display. Is there any indication of what the issue might be?
Add a comment
1 Answer
Most Helpful Answer
It's down to either the LCD or the backlight in this case since everything else appears to be working. Turn out all the lights in the room and hold a flashlight up against the screen and see if you can make out an image.
If so, then the backlight has failed. It could be either a board issue or a display problem; I'm not familiar enough with the iPad to be able to tell you where the backlight driver circuits are and if they're repairable or not, but hopefully some of our experienced Apple technicians will know.
Otherwise if it's the backlight itself or the LCD, either way you'll have to replace the display, which won't be cheap.
Score 1
Add a comment
Add your answer
redrott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 105
