Why does my washer leak during fill
I changed out the water fill valve. All connections are tight no leaking. Now my washer leaks at fill what could cause that?
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 22
All Time: 88
@annsanders can you verify for us that your washer is a MVWB765FW? Also, do you know where it leaks from, like the bottom, or the back or other places. Since you replaced the water inlet valves already, I would suggest to look somewhere near the drain pump.
by oldturkey03
