The Xterra was introduced in North America in the 2000 model year (1999 calendar year) and marketed using the tagline Everything you need, nothing you don't.
13 Questions View all
car stalls after running for 30 min.
I've replaced the fuel pump, fuel filter, and fuel pump relay. the only codes I get are for the cat. so I staight piped them both. still stalls after running for 30 min. starts fine after it cools down.
2 Comments:
@kijdfp08uw5vqvf what codes did you get?
by
PO463, PO420,and PO430
by
Add a comment
1 Answer
First off after changing all those parts did you reset the ECM? If not the auto still thinks the sensors are bad. Secondly it sound s like you original problem is electrical. Something is getting warm and going into default. Things like the coil and resistors for the ignition will not show on a code reader or self diagnostic reading.
Add a comment
Add your answer
mr.skeleton1969 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 12
All Time: 64
