Repair guides and disassembly information for Samsung's premium foldable smartphone, the Galaxy Z Fold3, released alongside the Flip3 in August 2021.
21 Questions View all
The 2 Screens not always working
I dropped my phone
The front screen didn't work, but the inside screen worked. I used the tap and massage the phone technique. The outside sceen now works, but the inside screen doesn't work. If I partially open it, I can get the screen to work intermittently. But once it's about halfway open the screen doesn't respond. I opened the phone to see if reconnecting the ribbon cables would work, or if I could find anything loose. I tried clearing the cache in safe mode. I've tried taping and massaging it more, no difference.
Is there a board or cable that I can replace, that might be a likely culprit? Is there a diagnostic software I could use to find the faulty part? Or any other ideas?
Thanks Dan Mayer
Score 1
Add a comment
1 Answer
Sounds like the display is the culprit here. Unfortunately, these devices are an expensive fad. While I think it's super cool that we've made a foldable display, it's nothing more than a gimmick to get you to buy a device that's twice as expensive to not only purchase, but also repair, with a higher failure rate.
1 Comment:
Both displays functioned after the drop, just not at the same time.
by
Add a comment
Add your answer
Danmayer2d will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 34
All Time: 376
