How to remove stripped screws
I wish to open the back of my MacBook Pro case underneath. The two centre screws remaining are stripped and I cannot remove them. Does anyone have any suggestions?
In the past, I've used a dremel tool to widen the area around the screw in the bottom plate so that the bottom plate can lifted up around the screw. Then the screw can be removed carefully by twisting it with pliers. Then later the bottom plate can be reinstalled with replacement screws. Be careful not to damage any components when using the dremel. Good luck!
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 30
