Wont power on at all after battery change
I was using the laptop one day and then it just suddenly shut off and would not come back on. I changed the battery and it still will not power on. Need some help on what the problem could be.
2 Comments
Hi @walla52779,
Does the laptop indicate that the battery is charging when the charger is connected?
by
No. There is no charging light indicator when plugged in
by
Add a comment
1 Answer
Most Helpful Answer
Hi Walla. I have come across a similar issue with 2 Lenovo Ideapads in the last 2 weeks. Remove the installed ram stick and the laptop should turn on. It is either the ram that has gone bad or the ram slot itself. With the 2 laptops that i dealt with, one was the ram slot that had gone bad and the other the black metal shield that was screwed over the ram. When i removed this shield the laptop powered up fine.
Score 1
Add a comment
Add your answer
Walla will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 206
