The screen is flickering and how to solve this
what is the cause of this and how to fix it. the startup and everything else is fine.
Hi @zainurizzat
Connect an external monitor (TV?) to the laptop's HDMI port and check what the display is like on it. Press the Fn+ F5 keys (both together) to toggle between the laptop display only, the external display only or both on together.
If the external display is OK there may be a problem with the video cable connection (loose?) between the motherboard and the display panel or more likely a problem with the laptop's display panel. Has the laptop been dropped or gotten wet at all?
Here's a video that shows how to replace the display panel in your laptop, that may help.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,045
