Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
38 Questions View all
Screen has a display but no touch screen after repair.
Hey I've got a Pixel 3a that touch screen suddenly stopped working. I suspect water damage, it was in my pocket during a pretty bad rain storm and after that the touch screen stopped working.
I replaced the screen with a non-genuine part because that's all I could find at the time, and the same issue persisted. I know it was a not genuine part because the colours are different.
My question is if there's another component on the board that could potentially be broken other than the screen? I was thinking about ordering another screen replacement (since iFixit sells genuine Google parts) but I want to see if there's anything else I can do before I pull the trigger, in case that's the issue.
Thank you!
Add a comment
1 Answer
Chosen Solution
Hello @kazuhiramiller, Yes can check out another screen placement, if it doesn't work that means you need to change the touch I.C
Score 2
2 Comments:
How difficult is it to replace the touch I.C? Is there a tutorial I can find anywhere?
by
Apologies, I've just read the teardown and I see it's on the ribbon cable for the screen itself. I'll order a new screen. Thank you for much for your help!
by
Add a comment
Add your answer
Kazuhira Miller will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 236
