Repair and additional information for the GE Refrigerator GFE26JGM****, an automatic defrost refrigerator without an ice-maker or a through-the-door dispenser, first available in 2019. This page covers information for model numbers matching the pattern GFE26JGM****.
1 Questions View all
Wiring connector assembly help
Removed the doors, while disconnecting the harness, the connector came off. The color of the wires don't match. We need help matching the wires back up
Black/yellow, white, 2 white/blue
Black yellow, white, red/white, gray/white
Update (05/05/23)
Update (05/05/23)
  • trying again
Update (05/05/23)
GFE26JGMWFBB is the model
Score 1
3 Comments
can you add photos
by
@dougwilds i can't see them doug it just says image
by
@dougwilds pictures can only be added to Question or Answers , not comments. It's fixed :-)
What make and model is this?
by
Add a comment
1 Answer
Most Helpful Answer
Hi @dougwilds
I can't find the mini manual (GE part #31-1000533) for a GFE26JGMWFBB but there are two models which are very close, i.e. GFE26JGMAFBB & GFE26JGMNFBB.
Unfortunately they have different mini manual part numbers not only from your model but from each other as well. Maybe there are slight variations in the wiring due to them having different features perhaps
At least they show the connections and colours of all of the wires used
GFE26JGMAFBB (31-1000396)
GFE26JGMNFBB (31-1000474)
Using an Ohmmeter, you may have to identify the wires by colour back to the main board connector pins, by looking at either of the manuals to see if one is appropropriate.
Hopefully one will be and then once you know where they connect to on the mainboard, use that manual to see where they go to and what colour wire they connect to or end up as.
Hopefully this is of some help.
Score 2
Add a comment
Add your answer
Doug Wilds will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 138
