The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
Is my switch completely broken?
Hi, I am wondering if anybody knows what is wrong. I have a Switch (got it from a bet) and I was wondering why it won't charge. I left it charging all night last night but it didn't charge. I tried all button combos, I have tried almost everything. I will try a new battery asap and I will have to see about a new Joy-Con pair because I need to know how to make my switch work. I will answer any questions you guys ask. Thank you for reading this.
4 Comments
@dudexslayer2004 Have you tried using the official Nintendo charger?
by
Fit a new charge port. See if that sorts it.
by
So uh my nintendo switch died because low batteries and its not charging now/ showing charging symbols.
by
And you've tried all the things I suggested for the original poster? What happens when you do?
by
Add a comment
1 Answer
Most Helpful Answer
Okay, when trying to diagnose charging issues, it's always best to start at the source and work your way into the Switch. So the place to start is with your charger; you'll need to verify that the charger itself is working, either by swapping it out with a different one, or trying the charger with a different device. Once you know you're getting power from the charger, the cable is next; again, either try a different cable or try the cable with a different device.
Now that we've eliminated all of the external factors, we want to take a look at the charging port itself. Take a magnifying glass and a bright light and check the port for any dust, dirt, or any other kind of foreign object inside the port. Clean the port with some 90% or higher isopropyl alcohol, maybe a microfiber eyeglass cloth and a toothpick.
Assuming it's still not charging, try wiggling the jack when it's plugged in; push to either side and up and down and see if you get any indication of charging in any position. If something connects with pressure on the plug, then you've likely got a damaged charging port that will need to be replaced. Unfortunately, it's a difficult job as it's soldered to the motherboard and requires a hot air station in order to change; it can't be done with just a soldering iron, so most of us would have to take it to a repair shop to have that done.
After that is the battery. Sounds like you have that covered as I assume you've ordered a battery, so if nothing has helped up to now, then that's the next step to put in a new battery.
Finally, if the new battery doesn't fix the problem then the only thing left is a problem on the logic board itself that requires board level repairs by an expert.
So check out the things I've mentioned, and if need be swap out the battery then let us know what happens. Good luck with your repair!
Score 3
1 Comment:
In addition, if you don't want to purchase a whole new motherboard then you could attempt to replace the charging port. Although this would require some experience with Micro-Soldering.
by
Add a comment
Add your answer
Dudexslayer2004 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 1,124
