Flagship smartphone from Huawei released April 2018. Model CLT-L29.
58 Questions View all
P20 pro motherboard wify fpc connector on board replacement?
Deconnecting the female signal WiFi flex cable I broke the male ipex connector from the motherboard.
So I need to buy new male connectors. Do you know which fit exactly to the P20 pro board and and where to buy them?
Score 2
1 Comment
Hi Oldturkey,
is it difficult tu put this part on the board again? How to do so and which tools I need for that?
by
Add a comment
1 Answer
Most Helpful Answer
@zarkokupresanin according to my schematic those are Huawei part number 14240433 Interestingly (but no surprise) there are no other identifiers on the schematic etc. You can do an online search with that part number.
I would use a caliper and measure the opposite connector (depth, diameter etc.) and see if Hirose or iPex (my money is on Hirose) have an equivalent. You can check either mouser.com or digikey.com to see if you can get one that fits.
Score 1
4 Comments:
Hi Oldturkey,
by
@zarkokupresanin not very difficult if you know how to solder. The solder pads look good so it‘ll be straightforward. If you have never soldered, I suggest you let somebody do it. It’s a fairly quick task. I good soldering iron some flux and solder is all you will need for this.
by
But these parts are very small - even though it is an easy fix?
by
@zarkokupresanin good light and some sort of magnification will works. For this work a headband magnifier Shopping will suffice.
by
Add a comment
Add your answer
Zarko Kupresanin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 103
