Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
116 Questions View all
Bad display or bad display cable?
Hi everyone,
I'm trying to help my colleague with his MacBook Pro 13" Late 2020.
Since 2 weeks, his MacBook Pro has glitching screen problem.
The issue happens with the lid open at a certain angle. If he raises or lowers the lid, the screen flicker with lines patterns like a broken display. When he closes the lid to put the MacbookPro in sleep mode and open it again, the screen stays black but with the backlight on. He needs to force shutdown the MacBook Pro to get a non glitched image it works sometimes but not always.
I'm wondering if this is a bad display or a if it's a bad display cable? Or do cables and connections need to be cleaned or checked first?
Here are some videos and images to show the issue:
Note:
This MacBook Pro had a water damage 2 years ago that let a spot on the bottom right side of the screen. But the MacBook Pro continued to work properly.
I hope the problem is clear enough to get your best help on this issue.
Thanks a lot for your help!
Carlos
Add a comment
Chosen Solution
I think this is most likely a failed display assembly or display daughter board. My recommendation would be to replace the display.
Score 1
2 Comments:
That's what I thought. I will order a new full assembly screen and try to fix it like that. As soon as it's done, I'll let you know the result. Thanks a lot.
by
No problem, good luck!
by
Add a comment
Hi Zach!
Sorry for the long time reply. I simply forgot to add some news about this repair.
So last year, I ordered a new screen assembly. Replaced it and since it works flawlessly! No more visual glitches! During the disassembly, I noticed some liquid residue on the screen flex cables and some bad wrinkles on it.
Here are some pictures of the repair:
Thanks again for your help!
1 Comment:
Nice! Thanks for the follow up!
by
Add a comment
Add your answer
carlitostyle will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 34
All Time: 259
