The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
81 Questions View all
My oil cap pops off where is the pressure comming from?
Where and what could be the cause
1 Comment:
how many miles are on the truck? What engine do you have?
by
Add a comment
1 Answer
If the cap gets blown off, there is too much pressure in the crankcase. Blow-by can be caused by piston rings that are worn out. A cylinder with worn out rings will have low compression and will likely cause a misfire. These piston rings need to be replaced.
Add a comment
Add your answer
Joseph Taitano will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 52
