Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
17 Questions View all
Charger and power indicator.
My laptop is critical low battery. When I plug in the charger the charging indicator will blink 3× times then power indicator which is blue blink and then they blink at the same time. What is the possible problem and the solution. Thanks for the answer.
Score 1
Add a comment
1 Answer
I have the same issue in the laptop. Mine is because I've used the charging port badly. It will probably need a change of the port.
Also, my fans turn up and down without any reason, and doesn't for a while when a game is being played- get's heated until I turn fans to max in NitroSense.
I don't know if that's related to the charging issue though.
Add a comment
Add your answer
MASHEEET will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 99
