A portable computer powered by a battery or an AC cord.
2 Questions View all
My laptop is broken, there is no voltage to the battery and the charge
my laptop is broken, there is no voltage to the battery and the charger indicator light does not turn on!
how to fix it?
is it affected by the charging IC?
Score 1
Add a comment
1 Answer
Hi Albert
I hope you doing well, I think there is many answers for your question, let's start with easy one
1-Make sure if the laptop charger work properly good to eliminate the charger issues.
2-Remove battery if it is external battery, disconnect the charger from your laptop, press and hold power button for 30 second and try to power up the device if it is working congratulation if not follow the next step
3-Broken dc jack (just fix it and the laptop will work again).
I did write simple eBook, it's talk about this kind of issues if you interest to get it just contact me.
Disclaimer:
Apply these solutions at your own risk.
Add a comment
Add your answer
Albert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 43
