A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
I can't unscrew my power supply.
So I was dissembling my PS4 following the guide ofcourse and then my screw bit couldn't unscrew the power supply and now the power supply screw top doesn't have define lines for a (ph-0) screw top. Any help?
Score 1
Add a comment
1 Answer
Most Helpful Answer
If you're unable to unscrew the power supply screw with a traditional screwdriver, you can try alternative methods. For example, you can use a rubber band or a piece of duct tape between the screwdriver and the screw head to increase friction and get a better grip. or heat a plastic pin and put it on the screw to take its shape of it then unscrew it using the pin.
Score 1
Add a comment
Add your answer
Monkey King will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 83
