The HP Laserjet Pro 200 Color MFP can be identified by its model number: CF145A. This wireless-enabled color multi-function printer provides ePrint, touchscreen access to apps, and versatile scan, fax, and copy options.
7 Questions View all
Why are papers printing with "smudges" on both sides?
Every page is printing with "smudges" on both sides from top to bottom. While comparing multiple papers, I noticed the smudges appear to look the same and appear in the same location from paper to paper. So far, I've removed the cartridge tray and gently cleaned along the edges of the transfer bed. I have also inspected the toner cartridges and I noticed that some yellow (last/4th cartridge) is showing on the edges of the pink toner roller (3rd cartridge).
Add a comment
1 Answer
Laser printers use static to transfer the toner partials from the drum to the paper, this is done by applying a charge via a wire near the drum we call it a chromatron. This wire can get dirty effecting the effectiveness of the transfer causing the smudge effect.
You need to clean and the drum as some toner has built up on it along the edge.
1 Comment:
Thanks Dan! Unfortunately, I ultimately concluded that it was a bad fuser.
by
Add a comment
Add your answer
Nick H will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 25
All Time: 127
