Repair and troubleshooting information for the Suzuki FA50 Moped.
75 Questions View all
My 50cc 2 stroke has sudden loss and regain of power when on high spee
My suzuki runs good from start
I cleaned the carb, feul tank, reed valves and the feul lines
As soon as i get up to speed it has sudden short losses of power
It doesnt have long losses of power and speed but does it in fast intervals of not even a second
Score 1
Add a comment
1 Answer
Chosen Solution
@hannesbuys since you already took care of most of the fuel issue and considering "does it in fast intervals of not even a second" I would check the timing. Check the magneto, coil and airgap. The SM for your Suzuki can be found here Suzuki-FA50-service-manual-1980.pdf
Score 1
2 Comments:
Thank you sooo much il have a look
I think there may be a chance of the problem being my transmition (the 3 gears on the back)
by
@hannesbuys you are welcome. REally hope you get that moped going again. Those are awesome. Anyhow, I am not sure if your transmission could do "but does it in fast intervals" that. Always good to go over everything and checking things out. Best of luck to you.
by
Add a comment
Add your answer
Hannes Buys will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 36
