2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Replaced left speaker but now screen is black
I replaced the left speaker in my MacBook Pro and had to remove the motherboard in order to do that. After finishing and putting computer back together, when I turned on the computer my screen is black but I can hear the startup sound
Add a comment
1 Answer
Most Helpful Answer
Using a flashlight shine it into the lids Apple logo (a poor man’s backlight), do you see a faint image of your desktop and its icons?
Score 1
6 Comments:
No, I unfortunately see nothing when doing that.
by
@michaelaspeaks - So the video signal is not reaching the display then. Check the displays LVDS cable and the logic board connector for damage.
by
I think you’re right, it might be the lvds cable. It looks like two prongs got bent when I initially put it back together.
by
@mspeaks57 - These are easy to damage. Now you have to replace the cable which will require taking off the display and replacing the cable MacBook Pro Retina (2012-2015) Display LVDS Cable follow this guide MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement focus on Step 4 in this MacBook Pro Retina Display Teardown you only need to get to the connector on the T-CON board.
by
Thank you! Just need to get the cable now
by
Show 1 more comment
Add a comment
Add your answer
Mspeaks57 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 80
