Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
198 Questions View all
I am getting occasionial kernel panics
I am getting occasionial kernel panics ,and the screen sometimes goes pink before the system shuts down
EtreCheckPro version: 6.8.1 (68024)
Report generated: 2023-06-10 15:21:00
Download EtreCheckPro from https://etrecheck.com
Runtime: 4:27
Performance: Good
Problem: No problem - just checking
Major Issues:
Anything that appears on this list needs immediate attention.
Kernel panics - This system has experienced kernel panics. This could be a sign of hardware failure.
Heavy CPU usage - Some processes are using an unusually high amount of CPU.
Minor Issues:
These issues do not need immediate attention but they may indicate future problems or opportunities for improvement.
Apps with heavy CPU usage - There have been numerous cases of apps with heavy CPU usage.
Unsigned files - There are unsigned software files installed. These files could be old, incompatible, and cause problems. They should be reviewed.
Runaway user process - A user process is using a large percentage of your CPU.
Kernel extensions present - This computer has kernel extensions that may not work in the future.
Hardware Information:
Mac mini (Late 2014)
Status: Supported
Mac mini Model: Macmini7,1
2.6 GHz Dual-Core Intel Core i5 (i5-4278U) CPU: 2-core
8 GB RAM - Not upgradeable
BANK 0/DIMM0 - 4 GB DDR3 1600
BANK 1/DIMM0 - 4 GB DDR3 1600
Video Information:
Intel Iris - VRAM: 1536 MB
HP M22f FHD 1920 x 1080
Drives:
disk0 - APPLE HDD HTS541010A9E662 1.00 TB (Mechanical - 5400 RPM)
Internal SATA 3 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 [APFS Container] 1000.00 GB
disk1 [APFS Virtual drive] 1000.00 GB (Shared by 11 volumes)
disk1s1 - macintosh HD (APFS) (20.32 GB used)
disk1s2 - Preboot (APFS) [APFS Preboot] (660 MB used)
disk1s3 - Recovery (APFS) [Recovery] (2.24 GB used)
disk1s4 - VM (APFS) [APFS VM] (4.30 GB used)
disk1s5 - macintosh HD - Data (APFS) (277.66 GB used)
disk1s6 - Update (APFS) (29 MB used)
disk1s7 - L*****************a (APFS) (2 MB used)
disk1s8 - L***h (APFS) (3 MB used)
disk1s9 - L**********a (APFS) (638 MB used)
disk1s10 - m******************* - Data (APFS) (239.23 GB used)
disk1s11 - m*****************a (APFS) (15.42 GB used)
disk2 - Samsung PSSD T7 1.00 TB (Solid State - TRIM: No)
External USB 5 Gbit/s USB
disk2s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk2s2 [APFS Container] 1000.00 GB
disk3 [APFS Virtual drive] 1000.00 GB (Shared by 6 volumes)
disk3s1 (APFS) [APFS Container] (15.42 GB used)
disk3s1s1 - L***h (APFS) [APFS Snapshot] (15.42 GB used)
disk3s2 - Preboot (APFS) [APFS Preboot] (379 MB used)
disk3s3 - Recovery (APFS) [Recovery] (1.12 GB used)
disk3s4 - VM (APFS) [APFS VM] (4.30 GB used)
disk3s5 - L***** - Data (APFS) [APFS Virtual drive] (313.13 GB used)
disk3s6 - Update (APFS) (11 MB used)
disk4 - LaCie Rugged USB-C 1.00 TB
External USB 480 Mbit/s USB
disk4s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk4s2 [APFS Container] 1000.00 GB
disk5 [APFS Virtual drive] 1000.00 GB (Shared by 5 volumes)
disk5s1 - B*************************I (APFS) (796.24 GB used)
disk5s2 - Update (APFS) (3 MB used)
disk5s4 - Preboot (APFS) [APFS Preboot] (25 KB used)
disk5s5 - Recovery (APFS) [Recovery] (20 KB used)
disk5s6 - VM (APFS) [APFS VM] (1 MB used)
Mounted Volumes:
Filesystem: APFS
Mount point: /Volumes/macintosh HD
Read-only: Yes
Used: 20.32 GB
Shared values
Free: 439.29 GB
Filesystem: APFS
Mount point: /Volumes/macintosh HD - Data
Used: 277.66 GB
Shared values
Free: 439.29 GB
Available: 440.81 GB
Filesystem: APFS
Mount point: /Volumes/L*****************a
Used: 2 MB
Shared values
Free: 439.29 GB
disk1s8 - L***h
Filesystem: APFS
Mount point: /Volumes/L*****1
Used: 3 MB
Shared values
Free: 439.29 GB
Filesystem: APFS
Mount point: /Volumes/L**********a
Used: 638 MB
Shared values
Free: 439.29 GB
Filesystem: APFS
Mount point: /Volumes/m******************* - Data
Used: 239.23 GB
Shared values
Free: 439.29 GB
Available: 454.42 GB
Filesystem: APFS
Mount point: /Volumes/m*****************a
Read-only: Yes
Used: 15.42 GB
Shared values
Free: 439.29 GB
disk3s1s1 - L***h [APFS Snapshot]
Filesystem: APFS
Mount point: /
Read-only: Yes
Used: 15.42 GB
Shared values
Free: 665.44 GB
Available: 676.21 GB
disk3s2 - Preboot [APFS Preboot]
Filesystem: APFS
Mount point: /System/Volumes/Preboot
Used: 379 MB
Shared values
Free: 665.44 GB
disk3s4 - VM [APFS VM]
Filesystem: APFS
Mount point: /System/Volumes/VM
Used: 4.30 GB
Shared values
Free: 665.44 GB
disk3s5 - L***** - Data [APFS Virtual drive]
Filesystem: APFS
Mount point: /System/Volumes/Data
Used: 313.13 GB
Shared values
Free: 665.44 GB
disk3s6 - Update
Filesystem: APFS
Mount point: /System/Volumes/Update
Used: 11 MB
Shared values
Free: 665.44 GB
Filesystem: APFS
Mount point: /Volumes/B*************************I
Used: 796.24 GB
Shared values
Free: 203.51 GB
Network:
Interface en0: Ethernet
Interface en1: Wi-Fi
802.11 a/b/g/n/ac
Interface bridge0: Thunderbolt Bridge
System Software:
macOS Monterey 12.6.6 (21G646)
Time since boot: Less than an hour
Notifications:
EtreCheckPro.app
3 notifications
Security:
Gatekeeper: App Store and identified developers
System Integrity Protection: Enabled
Antivirus software: Apple
Unsigned Files:
Launchd: /Library/LaunchDaemons/com.bjango.istatmenus.installerhelper.plist
Executable: /Library/PrivilegedHelperTools/com.bjango.istatmenus.installerhelper
Details: Exact match found in the legitimate list - probably OK
Applications:
352 apps
5 x86-only apps
3 unsigned apps
Kernel Extensions:
/Library/Application Support/CleverFiles/BackService.app
[Not Loaded] SecureDisk_11.kext - com.cleverfiles.SecureDisk-11 (1.0 - SDK 13)
System Launch Daemons:
[Not Loaded] 40 Apple tasks
[Loaded] 210 Apple tasks
[Running] 132 Apple tasks
[Other] One Apple task
System Launch Agents:
[Not Loaded] 19 Apple tasks
[Loaded] 200 Apple tasks
[Running] 138 Apple tasks
Launch Daemons:
[Loaded] com.bjango.istatmenus.installerhelper.plist (Not signed - installed 2023-03-28)
[Running] com.cleverfiles.cfbackd.plist (Justin Johnson - installed 2023-05-07)
Executable: /Library/Application Support/CleverFiles/BackService.app/Contents/MacOS/cfbackd
[Running] com.crystalidea.macsfancontrol.smcwrite.plist (Ilya Parniuk - installed 2023-03-28)
Executable: /Library/PrivilegedHelperTools/com.crystalidea.macsfancontrol.smcwrite
User Login Items:
[Not Loaded] diskcleanerlitehelper (App Store - installed 2023-06-03)
Modern Login Item
/Applications/Disk Cleaner Lite.app/Contents/Library/LoginItems/diskcleanerlitehelper.app
Backup:
Auto backup: Yes
Volumes being backed up:
L***h: Disk size: 1000.00 GB - Disk used: 334.56 GB
Destinations:
B*************************I [Local] (Last used)
Total size: 999.75 GB
Total number of backups: 20
Oldest backup: 2023-05-30 23:15:47
Last backup: 2023-06-10 13:13:30
8 local snapshots
Oldest local snapshot: 2023-06-09 16:12:56
Last local snapshot: 2023-06-10 15:13:42
Performance:
System Load: 7.65 (1 min ago) 7.41 (5 min ago) 3.95 (15 min ago)
Nominal I/O usage: 11.77 MB/s
File system: 28.38 seconds
Write speed: 413 MB/s
Read speed: 435 MB/s
CPU Usage Snapshot:
Type Overall
System: 10 %
User: 54 %
Idle: 35 %
Top Processes Snapshot by CPU:
Process (count) CPU (Source - Location)
mds_stores 110.04 % (Apple)
mdsync 69.66 % (Apple)
backupd 17.32 % (Apple)
WindowServer 5.40 % (Apple)
kernel_task 4.32 % (Apple)
Top Processes Snapshot by Memory:
Process (count) RAM usage (Source - Location)
EtreCheckPro 711 MB (Etresoft, Inc.)
mds_stores 195 MB (Apple)
kernel_task 83 MB (Apple)
Finder 82 MB (Apple)
WindowServer 77 MB (Apple)
Top Processes Snapshot by Network Use:
Process (count) Input / Output (Source - Location)
mDNSResponder 60 KB / 32 KB (Apple)
apsd 8 KB / 20 KB (Apple)
rapportd 3 KB / 3 KB (Apple)
netbiosd 2 KB / 578 B (Apple)
geodMachServiceBridge 0 B / 0 B (Apple)
Top Processes Snapshot by Energy Use:
Process (count) Energy (0-100) (Source - Location)
mds_stores 77 (Apple)
mdsync 38 (Apple)
mds 4 (Apple)
backupd 3 (Apple)
WindowServer 3 (Apple)
Virtual Memory Information:
Physical RAM: 8 GB
Free RAM: 19 MB
Used RAM: 3.06 GB
Cached files: 4.92 GB
Available RAM: 4.94 GB
Swap Used: 0 B
Software Installs (past 60 days):
Install Date Name (Version)
2023-04-16 Pages (13.0)
2023-04-16 Numbers (13.0)
2023-04-16 Live Gallery (1.0.1)
2023-04-17 1-Click Video Converter (6.3.55)
2023-04-18 macOS 12.6.5 (12.6.5)
2023-04-24 CyberLink PhotoDirector 365 (1.0)
2023-05-04 Disk Drill Media Recovery (4.5)
2023-05-07 AVG Cleaner (4766)
2023-05-20 Safari (16.5)
2023-05-20 macOS 12.6.6 (12.6.6)
2023-06-03 CleanMyMac X (4.13.5)
2023-06-03 Disk Cleaner Lite (1.7)
2023-06-10 XProtectPayloads (99)
Diagnostics Information (past 7-30 days):
2023-06-10 15:12:41 mdsync High CPU Use (12 times)
Executable: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdsync
2023-06-10 08:46:03 bluetoothd Crash (2 times)
Executable: /usr/sbin/bluetoothd
Details:
libsystem_c.dylib: abort() called
2023-06-07 10:01:26 Kernel Panic (3 times)
Details:
panic(cpu 2 caller 0xffffff800f91ccd6): initproc exited -- exit reaso
n namespace 2 subcode 0xa description: none
2023-06-06 19:11:19 com.apple.WebKit.WebContent High CPU Use (3 times)
Executable: /Library/Apple/*/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
2023-06-06 10:34:38 Spotlight.app High CPU Use
Executable: /System/Library/CoreServices/Spotlight.app
End of report
Add a comment
1 Answer
Most Helpful Answer
What are you running on the system? The report implies something quite heavy with graphics.
This systems graphics is quite limited, you maybe pushing it past its ability. I would clean the fan and the heat sinks fin area to make sure you are getting the maximum cooling the heat sink offers. I would also install a good thermal monitoring app like TG Pro which allows you to visually see what’s happening within your system and even boost the fans RPM to maximize the cooling.
Sadly your system is locked in with only 8GB of RAM as it’s soldered to the logic board in this series, only at time of purchase can you get a 16GB system.
Score 1
1 Comment:
so could it be my desktop photo that is causing the problem, I have it set to change every 30 minutes
other than that all I can Think of is
garageband
Xcode
and my photo library which contains 135 photos and 30 videos
by
Add a comment
Add your answer
Lethal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 175
