First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130 Questions View all
I can’t connect disabled iPad because it is not on internet
Can someone please help me. My iPad says “iPad disabled, connect to iTunes. I can’t find how to connect to iTunes, but looked up some other ways. Unfortunately this did not work because my iPad is on airplane mode for some reason. My iPad is also really old. Thanks for all the help!! Also, I had no idea what type of iPad I have so I completely guessed.
1 Comment
Look on the back of the iPad for the model number. Plug that into here to see what it is: https://everymac.com/ultimate-mac-lookup...
by
Add a comment
Most Helpful Answer
you have to download itunes onto a pc or laptop, then connect the ipad to the pc with the charge cable
Score 1
Add a comment
You need iTunes. Then as stated connect to iTunes. The bit missed was put the iPad into dfu mode whilst connected. To do this press and hold power and the home button together for about 8 to 10 seconds then let go of the power button whilst keeping the home button pressed. If successful you should hear a tone and iTunes will say, iTunes has detected a iPad in dfu mode. You must restore this iPad before you can use it.
Good luck.
Score 1
Add a comment
Add your answer
Hannah will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 31
All Time: 230
