What is the correct name of this part? Where can I buy?
Hi I was wondering what is the name of this part? Where can I find to buy it if possible? Thank you in advance. Part I'm looking for is part on motherboard. The cable that connects to it is part of EDP cable but is not EDP. It says JGYRO on motherboard area.
this is pic
of it on motherboard the black 10 pin one.
7 Comments
@thalotarutaru take a picture of your board straight down. Not at an angle. What is with the cable, since half of your images refer to that? Are you looking for the motherboard connector or the cable? What motherboard is this? LA-K741? your computer is a Dell Alienware m17 R4
by
@oldturkey03
Looking at the service manual for the laptop, I think that the socket connects the G-Sensor to the motherboard.
As to the correct socket type hopefully the schematic (once board model is known) will state what type it is, to find out the correct pin pitch to match the cable.
Cheers
by
Yes it's the LA-K741
by
@oldturkey03 yes it is the la-k741 like you said thanks for replying. Also sorry for late reply was at work.
by
@jayeff hello thank you for replying jayeff. Yeah I'm trying to look for part that's on the motherboard because it ripped off and so did the pins. Once again thank you for taking time to reply.
by
Show 2 more comments
Add a comment
1 Answer
Most Helpful Answer
@thalotarutaru of course a schematic or Board view is not available for your motherboard. However, the LA-J521 shows the same connector. It is a Dell favorite ;-). The connector is a ACES 50521-01041-P01 FPC 10P Connector
Update (06/23/23)
I just compared the service manual for the Dell Alienware M17 R3 which uses the LA-J521 against the Dell Alienware M17 R4 which uses the LA-K741 and both connectors are identical. That means your connector is a ACES 50521-01041-P01 FPC 10P according to the schematic
LA-J521
LA-K741
Score 2
8 Comments:
Hi @thalotarutaru,
If it is the correct part then here's a link to a parts supplier that may help.
by
@jayeff by locking latch do you mean the white piece that locks connectors in place? Piece I need is all black and has pins connector on top inside and it comes out back to go on motherboard. Thanks again. I'm trying to find a pic to that connector.
by
@thalotarutaru all we need is a good picture of „your connector“. No stock photos from somewhere online. Just the one you have on your board will be fine. Straight on good clear picture. Not angled, crooked rotated or out of focus would be best. 👍🏻
by
@oldturkey03 the black one is a pic of my connector the real one the one with only three pins inside. The rest broke off. I'll try to send more pics when I get home. It's hard to take pic of that small piece but I'll try again.
by
@oldturkey03 I'll edit my post with more pics hopefully it helps now
by
Show 3 more comments
Add a comment
Add your answer
Thalo Tarutaru will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 28
All Time: 197
