The G502 Hero has the same ergonomic design as its predecessor, with an updated sensor. Released in 2018 and identified by model number M-U0047.
11 Questions View all
Scroller button verso destra stops working with light touches
my "scroller button verso destra" stops working with light touches on occasions and I have to press harder and turning the scroll forward, instead the opposite button works without problems
Add a comment
1 Answer
Sounds like the scroll wheel encoder. I actually just had a similar issue on my G603, here is the guide for that encoder replacement so you can have and idea as to what this entails.
To figure out the exact part you need you may just need to disassemble your mouse and check the part for the wheel encoder. Here is a disassembly guide for the G502 Hero. You may even find that after taking it apart and cleaning it it works again! If not just search Ebay for that part and you should be able to find it.
Logitech G502 Hero Image
Guide
Logitech G502 Hero Disassembly
Difficulty:
Moderate
1 hour
Logitech G Series Mouse Wheel Encoder Image
Guide
G603 Wheel Encoder Replacement
Difficulty:
Easy
10 - 20 minutes
Add a comment
Add your answer
JDMys will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 73
