Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
17 Questions View all
I drop soda on keyboard
I drop soda in my keyboard and it turned off on me within 10 seconds i took the back off and it seems like only the battery took most it wint turn on does it need a new battery?
Add a comment
1 Answer
Most Helpful Answer
Hi @williamtaker
The impurities in the soda (or any liquid except distilled water) causes corrosion and provides circuit paths for the electricity which were not in the laptop's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your laptop and then remove the battery as soon as possible from the laptop to minimize any further damage.
Then you need to dis-assemble the rest of the laptop and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well.
Keyboards are hard to clean and you can cause more damage than what there already is if you try to. Most repairers simply replace them
Hopefully after you have done all this the laptop might possibly work correctly again.
Here is a teardown video for the laptop that may help
If this process seems too daunting, take your laptop to a reputable, professional laptop repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 1
Add a comment
Add your answer
William Taker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 192
