Fix Left click button
Left click don't work while all other buttons work properly
Imad, when you press the left click button, does it still make a sound? If not, you probably either need to replace the switch (the mechanism that registers clicks) or buy a new mouse (if you don't want to disassemble your mouse), and if so, it's probably something a bit more complex, in which case I would heavily recommend buying a new mouse.
Dear Shingle
Thank you for your quick reply.
Yes i still have a click sound ;what to do in this case?
@imadchidiac Well, that means that the switch isn't broken. What specifically are you using the mouse for? Also, how long have you been using it for?
I used for a smart TV less than a year
Hmm. And all the other mouse buttons work? That's quite strange. Have you tried using a different mouse? If left-clicking doesn't work with the different mouse, then it is a problem with your smart TV. If left-clicking does work with a different mouse, then you should probably just buy a new mouse. Personally, I would recommend the Logitech K400 Plus if you want a trackpad-keyboard combo, or either the Logitech M705 or M330 if you already have a keyboard (the M705 has better battery life, but is slightly more expesnsive, and both mice are on sale).
Maybe worth a try--what do you have to lose?
(I'd use electronic cleaner or 91/99% alcohol instead of WD40):
https://www.youtube.com/watch?v=-w-W6MAn...
Good luck!
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 48
All Time: 2,312
