The DeLonghi ESAM family of products is a line of automatic coffee machines for making lattes, cappuccinos, espressos, and other drinks. Look for the model number ESAMxxxx on a sticker on the back or bottom of the device.
23 Questions View all
Delongi Ec860 will only send water to diffuser if jump the 93 solenoid
When selecting coffee shot the water only reports to overflow 77 at tray. The only way to get water to the diffuser location is by jumping the 93 solenoid with the wires from the 92 solenoid. Is this a power card issue?
1 Comment:
@rocky71964 let's see if the coffee maker guru can help you out with this one. @vauweh what's your take on this issue? Bad solenoid or bad power supply?
by
Add a comment
1 Answer
If water flows through 93 when connected, it seems to be OK. I would try to measure the voltage on 93 when coffee ist selected. If it remains to zero, the power supply may be bad. Follow the wires. Perhaps a faulty relais, transistor or triac? Good luck!
Add a comment
Add your answer
Rocky will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 43
