Guides and repair information for dryers produced by Bosch, a German engineering and technology company.
5 Questions View all
What sensor can cause F09 fault? Machine stops, clothes are still wet.
During the cycle my machine stops running displaying F09 fault. The cloths in the machine are still wet. I can restart the dryers, but sometimes it stops again, sometimes it keeps running till the end. When the machine complete the full cycle, sometime cloths are still not dry however the sensor should measure this. How can I find if the humidity sensor is failing or the over temp sensor is failing or......
Add a comment
1 Answer
Most Helpful Answer
Doing a search indicates that your dryer temperature sensor has failed. "NTC" broke. Ntc is a thermistor. You should be able to replace it.
Score 1
1 Comment:
Hey thanks,
I will find how to replace the the NTC, This will be probably the root cause.
I will leave a message when it is replaced.
by
Add a comment
Add your answer
Hans dusar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 107
