Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
593 Questions View all
Upgrade RAM on late 2011 MacBook Pro
What’s the max amount of RAM I can put into a Late 2011 MacBook Pro? I wanted to upgrade to 16gb. With i5 processor. Also want to upgrade the drive to a SSD. Doing this cause on a budget and can’t afford a new laptop. Not even refurbished. Lol
Add a comment
Most Helpful Answer
It should be able to handle a max of 16GB. (8GBx2). You may want to just try the SSD alone first and see if the performance is good enough for your needs before you buy the extra memory.
Score 2
1 Comment:
Thank you for that. Yeah was thinking just the SSD as well. But was still curious on the max RAM.
by
Add a comment
RAM Type:PC3-10600 DDR3Min. RAM Speed:1333 MHz
Standard RAM:4 GB Maximum RAM:16 GB*
Details:4 GB of RAM is installed as two 2 GB modules, no slots free.
*Apple officially supports a maximum of 8 GB of RAM, but third-parties have determined that this model actually is capable of using up to 16 GB of RAM with two 8 GB memory modules.
Score 2
Add a comment
Am using 16GB of RAM plus have converted original HD to SSD (1TB) and have removed the CD drive and have added another SSD (1TB). It works good.
Add a comment
Add your answer
MikeLex6398 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 57
